06-28-2023 17:52
06-28-2023 17:52
Is anyone else having this problem? My phone and watch will not sinc with each other! Never had this problem!
Best Answer06-28-2023 22:12
06-28-2023 22:12
Yes. Since request to change togoogle account.
Best Answer06-29-2023 10:57
06-29-2023 10:57
My 5th Fitbit watch and I have never had this watch synch properly.
I use my watch to alert me of messages and incoming calls. I have had many knowledgeable individuals try to fix it.
I also don’t get the time when I raise my wrist.
I so frustrated I’m thinking I’ll have to go to an alertnative brand.
06-29-2023 11:52
06-29-2023 11:52
Same here
Best Answer07-07-2023 11:09
07-07-2023 11:09
i have also the same problem and now it's not charging as well. i checked my charger and its working but my Sense 2 doesnt getting charged
Best Answer07-08-2023 18:27
07-08-2023 18:27
Best Answer07-10-2023 04:52
07-10-2023 04:52
Have you tried restarting your phone and watch?
Best Answer07-10-2023 04:53
07-10-2023 04:53
To do so with you watch, press and hold the button for 10 secs until you see the Fitbit logo. For the phone, just restart it, then try syncing after making sure you are connected to the internet and your bluetooth is on.
Best Answer07-10-2023 06:58
07-10-2023 06:58
Also, it would be helpful if you all posted your OS, the make, and model of each of your phones. Last time I checked, the Fitbit app needs to be running on Android 8.0 (not sure about Apple phones as I'm an Android gal) in order to function.
one cruise ship at a time!
Best Answer07-10-2023 07:03
07-10-2023 07:03
Mine runs on Android 12...
07-10-2023 07:03
What OS do you use?
Best Answer07-10-2023 07:05
07-10-2023 07:05
Mine is on Android 13.
