Sense 2 Can't set pin for Google Wallet
ANSWERED
I have been through 3 support chats and no help. The app says I have to set a pin to use Google Wallet. The bottom button says CONTINUE. Next page there are 4 dashes to enter a pin. I enter the first number and that's as far as I can go. I've tried every number. I've removed and readded the Sense 2 on the Fitbit app. I've reset Sense 2 to factory settings. I've done those at least 4 times over 2 days. One support person said wait 24 hours and try again. I did but no change. I had Fitbit Pay on my Charge 4. I use Google Pay on my Android. I added Google Wallet to my phone wondering if that would make a difference. At this point Google Wallet is just a useless colorful tile. Trying to access with my watch just tells me to set it up on the app and goes into syncing mode but it can't sync because I can't complete the setup by adding a pin.
1 BEST ANSWER
Accepted Solutions
Hi @Debddp7 - this is a common issue and relates to the phone. Some say long press for each digit works others say change to the native keyboard if it is an Android phone.
5 REPLIES 5
You're a lifesaver. I had to Google 'native keyboard' which brought up
Grammarly. I downloaded the Grammarly keyboard app and made that the
default keyboard. Adding the pin was no longer an issue. Cards added and
easy to access on the watch. Thanks!!
I faced the exact issue with my Versa 4 and it has been resolved, finally!
  • Connect phone to an external bluetooth keyboard
  • Enter the 4 digit pin
  • There's no button on screen to proceed, nor does pressing enter on the external keyboard help.
  • Tap on the phone screen again, on the 4 digit pin field to bring up the virtual keyboard within the phone again, there is a 'Next' button in place of the enter button.
  • Click on 'Next' then key in your pin again to confirm and you're all set.
Some other things i've tried that didnt work:
  • Call agent told me that selecting 'Factory Reset' on the watch's setting module would give the Fitbit pay function back, so i have a payment method in the meantime while the tech team look into it, no it doesnt. Still shows prompt to set up google wallet.
  • Pressing on the digits for a long hold to bring up another virtual keyboard, no doesnt work.
  • Specs: Android, Samsung Note 8.
Hope this helps! Seems like a long time issue but when i called the call centre, they dont seem to be able to help or even aware of this.
I tried chatting with Fitbit Support and that solved nothing.  Seems that Tech Support would send out tips & tricks for common issues like this would be a given.  When I worked for Gateway Support, we constantly received memos for things like this.
Adding the Grammerly keyboard worked for me as well.
Thanks!
I'm surprised this hasn't been sorted out by Fitbit yet.
I worked-around the issue by connecting a bluetooth keyboard to my phone.
