Sense 2 - Changing my run settings
ANSWERED
When I click exercises and run I'm not able to change it to auto laps, the run starts before it let's me change the settings. How do I do this?
1 BEST ANSWER
Accepted Solutions
Hi @Jmussel   Are you starting your run by tapping on an icon this tile?
These are Quick Start shortcuts -- tap and go.  If you want to make changes from this screen, please do the following.  Tap on All.  Tap on Run in the list.  Swipe up on the tiny "^" on the bottom of the screen to get to the settings.  Fix your lap settings there.
Laurie | Maryland
4 REPLIES 4
Agreed, that is such a nuisance.  The only way I have found is to start another exercise type you never do, then stop it right away, repeat for 2 other exercise types.  That will remove 'run' from the list of your top 3 types. Then you can choose it and have time to scroll down to adjust the settings.
Laurie | Maryland
Wow! I didn't realize that @LZeeW .  If I tap on one of the 3 recent ones at the top, it does start up being able to make any changes. But if tap 'All' to choose that same exercise type, probably at top of that list, then you can make changes.  Can't imagine how you figured that out but great to know.
@JohnnyRow   I remember writing my answer dozens of times when the Sense 2/Versa 4 were new.  I took a closer look at my Sense 2.  I think something changed in a firmware update.  When I tap on a quick start icon, I see the tiny "^" that wasn't there before.  I can swipe up and can see the Settings, but then the workout starts.  Counterintuitive.
Laurie | Maryland
