Sense 2 - Device not turning on and showing a red X
Hello, my Fitbit sence 2 isn’t turning on i charge it I can see logo then it shows a red X
Moderator edit - updated subject for clarity
16 REPLIES 16
Mine is the same. Can't figure it out.
Mine is the same, and it will not connect on my iPhone. It occasionally turns on and I see the fitbit logo when it starts up and then will not go past the instructions page.
Also having the same problem since yesterday, battery was at 53% when it went off
Mine just started doing this too. Pretty frustrated. It was at 21% when it went off
Mine is the same suddenly stopped working & now won’t connect tried all restarts & I have uninstalled my app but now my Bluetooth will not show my Fitbit to connect to ….
Same for me after the latest update.
Hi everyone, I hope you are doing well.
I'm sorry to see you are finding trouble with your Sense 2 that is showing a red X. I appreciate the efforts you all have already done.
First of all, don’t unpair your device or uninstall the Fitbit app because you might not be able to pair the device again.
Instead:
- Attempt to sync the device in the Fitbit app. From the Today tab, tap the devices icon and then their device and then Sync Now.
- If Sync Now doesn’t show an update banner, tap the devices icon > the image of the Sense 2 > Gallery. The app should show a pop up to install the missing apps and recover the device.
- Restart their device. Refer to How do I restart my Fitbit device? Help Center article for instructions.
Did not work for me.  The device syncs but screen does not turn on.
Still not working... The device is sync but once take off from the charge cord, it doesn't turn on
Here are some things to try...
Fitbit Sense 2 Not Turning On
If your Fitbit Sense 2 is not turning on, there are several troubleshooting steps you can try:
Press and Hold the Button: Press and hold the side button for about 10 seconds until you see the Fitbit logo on the screen, and then release the button.
Check Charging Contacts: Clean the charging contacts on the back of the device and on the charging pad with a toothbrush dipped in rubbing alcohol. Ensure they are dry before charging.
Charge Fully: Ensure the device is fully charged. Sometimes, a full charge is needed for the device to turn on properly.
Force Restart: Disconnect the charger and press the side button for 10 seconds. Then reconnect the charger and press the button again for 10 seconds.
Factory Reset: If none of the above steps work, you may need to perform a factory reset. This will erase all data on your Fitbit Sense 2, including your settings and saved workouts. To factory reset, open the Fitbit app on your smartphone, tap on your device, and look for the option to reset it. Follow the on-screen instructions.
If these steps do not resolve the issue, it might be necessary to contact FitBit support.
Good luck all.
Hi there,
The watch only works when connected to the charger. When you remove it, the
Hold the Button option does not work. Nothing happens. The watch is charged
100%. I have already performed the factory reset with the watch on the
charger. It still doesn't work.
Thanks!
I was advised to un pair my sense 2 & yes now it does not show to pair with I have tried everything wil this be able ti be fixed ?
As usual, none of these supposed "fixes" work.
I have contacted the help centre today via phone & thay have sorted this My fitbit is back up now all sorted
Hi everyone! I'm glad to hear that your were able to resolve your issue @Jacqui37 with the help of our help center.
For those who are still having trouble with their devices, my bes t device at this point is to contact our tech support. They count with better resources to investigate more in depth. I appreciate your time in this process.
First of all actual issue is not with pairing.
It's very clear that after firmware update for Sense 2, it won't powerup without putting charger on even though battery shows 100%.
After powerup with charger plugged in, it gets paired with mobile app.
But after sometime when you remove the charger watch gets switched off in few minutes. After that when we try to power up it shows RED X SIGN on sense 2.
I have done all measures mentioned here like unpair, forced restart, mobile app reinstallation, Sense 2 factory reset.. etc.
Still same issue is there. It shows red cross when powered up.
Is it true that google purposely did such firmware update to "Fitbit" users??
