05-14-2025
02:56
07:36
DavidFitbit
05-14-2025
02:56
07:36
DavidFitbit
I think my sense 2 is broke and I would like other people's opinions...
My Fitbit won't actually stay on... It circles through the loading screen (flashing white and blue) and then a red X appears and then it just dies. This happens over and over....
I did disconnect and reconnect Fitbit to the app and it worked for a few hours and then it started doing it again.
05-14-2025 09:15
05-14-2025 09:15
I'm having the same issue! Ugh!! I've tried restarting but still got the red X
05-14-2025 09:28
05-14-2025 09:28
Yep it's annoying....
Just out of curiosity has your battery been going really quick too?
Best Answer05-14-2025 10:17
05-14-2025 10:17
Best Answer05-14-2025 10:20
05-14-2025 10:20
Same here! 😞
Hopefully there's a simple resolution!
Best Answer05-14-2025 16:15
05-14-2025 16:15
Yeah, so I just bought my Sense 2 yesterday. It did an update yesterday worked fine. Then about an hour ago this exact thing. In the app it appeared it was trying to update again. Then suddenly it was no longer attached to the app. All I get is exactly as described. Flashing white and blue then red X. This is GREAT!!! Brand new device worked 24 hours and now just gives me a red X.
05-14-2025 17:02
05-14-2025 17:02
So, I contacted FitBit support and went through all their suggestions. I now have a refurbishment replacement heading my way. Buy brand new, get a refurb sent the next day. *sigh*
Best Answer05-15-2025 21:47
05-15-2025 21:47
Really? That's not good is it.
Refurbished one instead of a brand new one is bad!
So did they say what was wrong?
Best Answer05-16-2025 05:05
05-16-2025 05:05
I've been in touch with Fitbit support.
They advised me to factory reset. So I did and my Fitbit also updated. It seems to be working now.
But for how long? They also stated they don't know why the Fitbit is doing a loop with a red X.
I have to get back in touch if it happens again.
05-16-2025 05:49
05-16-2025 05:49
Nice! I hope yours does not do that again.
Mine did not come back to life with the factory reset. They did not seem to know what was causing it. It did look like mine at the time was trying to do an update. Maybe a recent update had problems.
I hope my replacement comes soon and that it works for more than a day. 😂
Best Answer05-16-2025 08:48
05-16-2025 08:48
Hi there, @KimberleyMichel, @Smartgirlie and @ChrisBerryOhio.
@KimberleyMichel and @ChrisBerryOhio Thanks for sharing the steps that you've tried prior to posting. I'm sorry for any inconvenience caused by this. Our team is constantly working to improve our devices, and the input we receive from our members is a big part of the process. I'm glad you received help and I hope you can keep crushing your goals.
@Smartgirlie Thanks for your efforts and to work on this together, may I know if you've checked our battery life tips? As with any electronic device, the battery life will depend on how often certain features are used, such as GPS or animated clock faces.
In addition to this, please try forgetting your Sense 2 from the Bluetooth settings. Then, open the Fitbit app, tap Devices at the upper left corner > Add More Devices and select your watch to reconnect it to your account.
Best Answer05-16-2025 10:35
05-16-2025 10:35
Although mines working at the moment.... My battery is still going down very quickly. I also read the battery life tips. 🤷:female_sign:
Best Answer05-18-2025 23:34 - edited 05-19-2025 07:48
And....... It's doing it again!
I now have to send my faulty Fitbit to Google and hopefully getting a replacement.
05-20-2025 08:24
05-20-2025 08:24
Hi there, @KimberleyMichel.
Thanks for keeping me posted. While I'm sorry that your Sense 2 isn't working correctly, I'm happy that you got in touch with our Support team. I'm sure they'll continue helping you so please keep an open communication with them.
I hope to see you back on track soon!
Best Answer06-04-2025 16:48
06-04-2025 16:48
OK,
My Sense 2 is now doing the same thing… died during middle of the night so didn’t complete sleep tracking- recharged it before heading to gym for workout- died again during workout after appearing to successfully track exercise for awhile. Now will not take a charge enough to operate- all it does is the Blue/ White alternating screen flashing with the Fitbit logo - 8 cycles, then a big Red X.
Any suggestions? I rely on my Fitbit daily and really hope to get it working again!
thanks,
Bill
06-05-2025 05:19
06-05-2025 05:19
You want to get in touch with Fitbit support. I did and they sent me a new device after I had sent my faulty one back to them.
06-05-2025 05:21
06-05-2025 05:21
Mine is almost 2 years old, they won't do anything....thanks tho !
06-05-2025 05:35
06-05-2025 05:35
They will. Mines over two years old. You just have to have proof of purchase. 🙂
Best Answer06-05-2025 13:52
06-05-2025 13:52
I'll give it a go so....thanks !
Best Answer06-05-2025 14:55
06-05-2025 14:55
Hi there, @ALEstrange and @KimberleyMichel. @BiiF Welcome on board.
@BiiF Thanks for the details provided, and your efforts while working on this matter. Your feedback is also appreciated as it helps us to keep improving your experience with our devices. I went ahead to check your details and it seems you already got in touch with our Support team. I'm glad your case is in their hands, so please keep an open communication with them should you have more questions. I'm sure they'll continue helping you with your Sense 2.
@ALEstrange Thanks for bringing this to my attention. I understand where you're coming from and I'm sorry for this experience. Since you mentioned the button isn't working well, may I know if you feel a vibration when pressing it? Because your post didn't mention, please try restarting your watch to refresh its performance. If the button is responsive again, you can try forgetting your watch from the Bluetooth settings, going to the Fitbit app and setting it up as a new device.
@KimberleyMichel Thanks for your input. I'm sure your posts will be of great help for our members.
