Is there a screen protector for the Sense 2 device that allows full functionality? All the ones i’ve seen don’t seem to allow you to use some of the functions of the device that require the edges of the watch to be touched i.e the EDA scans.
Best AnswerMany thanks for responding but 30 quid for a screen protector is a bit excessive 😦 and it doesn’t seem to be available other than from the US.
Thanks for getting back to us and for sharing your Sense 2 screen protector query @PeterH62.
Upon verifying I was able to confirm that the screen protector is in the U.S. store. Where are you located?
Thank you for your assistance and the heads up @Odyssey13.
@PeterH62you in the UK?
@AndreaFitbitdo you know if it's available in the UK?
Hi @Odyssey13. Thanks for getting back to us.
I checked the UK store and the screen protector is not available there.
I also checked other locations and I found out that it's available in Spain (it wasn't available there before). @PeterH62, you can stay tuned to your country store and see if the screen protector gets available there.
