11-12-2023
13:11
19:40
JuanFitbit
11-12-2023
13:11
19:40
JuanFitbit
My Fitbit sense is showing military time and I can’t remove it and I want it off. I have checked all my settings and they are correct, any suggestions?
Best Answer11-12-2023 19:41
11-12-2023 19:41
@bdmileikowsky , A warm welcome to the Community !Thank you for your efforts.
Just to confirm. Did you tried the steps described here:
How do I change to a 12 or 24 hour clock? right?
11-12-2023 21:10 - edited 11-12-2023 21:11
Hi @bdmileikowsky - in addition to what @JuanFitbit has provided try pulling down on the watch and turn off all the icons.
If you have Always On enabled you can get the default built-in clock with time in 24hr mode. Without it when you turn your wrist you should see the time. If this isn't sufficient try changing to another clock face with it's own Always On clock face and that may also work.
