10-18-2023
05:08
20:10
EstuardoFitbit
10-18-2023
05:08
20:10
EstuardoFitbit
Hello.
I have this question. Is it said what widgets and applications can be uninstalled from the watch? I ask because I noticed that with some widgets, pressing the "Uninstall" key does not do anything despite the fact that the install key appears after a while. Based on this, I deduced that those widgets with this symptom are probably associated with some applications, and until you uninstall them, these widgets cannot be removed either. (If that's the case, well that's a very stupid move).
An interesting case for that is the "Weather" widget, because once it accidentally deleted itself for me and now I can't restore it (and after all, the system weather application is permanently installed, so why did this widget let itself be uninstalled?!).
And one more bug. The watch does not reproduce the order of tiles that is shown in the app. How to fix it?
I don't want to do a factory reset for these simple errors,
I have the Fitbit 3.90 app for Android.
