I charged my sense 2 to 100% at 9:00 last night. By 630 this morning it was down to 30%. This has never happened before.
10:04
06:36
05-16-2023
10:04
06:36
Thanks for getting back to us @SunsetRunner and I'm sorry to hear that your Sense 2 battery is draining quickly.
Thank you for your comments and advise: @N8teGee and @SunsetRunner.
Please check help article: Can I extend my Fitbit device's battery life?
Best AnswerHi @SunsetRunner.
Have you recently changed watch faces or any settings on your device? Firstly I'd recommend restarting your device by pressing and holding the button for 10 secs. Charge the device again and monitor it to see if this has solved the excessive drain.
Ok thanks for confirming.
As mentioned above, try the restart and update us as to whether that makes a difference. It may have just been a stuck process and restarting should hopefully kill any active processes.
10:04
06:36
05-16-2023
10:04
06:36
