04-11-2023 09:58
04-11-2023 09:58
Does anyone else have an issue with their battery life for the sense 2?
Mine requires at 2-3 charges in 24 hours to have it last. I have now removed every feature that makes the Sense 2 essentially the Sense 2. To my shock, when I asked Fitbit for support, their solution was to "remove all battery draining features" including anything that made the Sense 2 what it is.
I've seen issues with this watch on multiple forums and would like to find others with the same issue so that together we can hold Fitbit accountable about it's transparency of battery life. Their site claims the Sense 2 can last 6 days. If a device can't last 24 hours with the features it is sold on, then the device is not what it is and it is a scam. I would have bought the cheaper versa had I know.
04-11-2023 19:38
04-11-2023 19:38
Hi @anniemiccia - your post is moved to the Sense 2 forum in order to help better.
A watch with such short battery life is most likely faulty unless you are using it to track sports and using the GPS a lot. It is rated at 5 hours maximum.
As it is new get it replaced under warranty or did you know if you are unhappy with the watch, Fitbit have a 45 day refund policy or possibly authorised dealers too, some stores provide 14 to 30 day refunds.
04-11-2023 20:08
04-11-2023 20:08
06-21-2023 23:16
06-21-2023 23:16
I agree. My battery lasts maybe 24hrs now before I get a warning to recharge.
06-24-2023 12:16
06-24-2023 12:16
I agree absolutely i just bought 2 set of sense 2 one for me second one for my wife. I just bought the today from a store in Germany. Battery charged to 100% after one hour it’s 0%!!!
we feel that we have been cheated
06-24-2023 12:27
06-24-2023 12:27
Hi @Nabil_Q8 - a version of the firmware presented battery level wrong - try restarting the watch by holding the button for 10 seconds till vibrates and the logo appears, and recharge it again, if that doesn't work. Note pulling down on the watch face shows the battery level but you may have to wait a while for the correct value to show.
06-25-2023 19:14
06-25-2023 19:14
I just started using the sense 2 few days ago and it has needed to be recharged after 10 - 12 hours. Can't wear it to sleep because it's on the charger at night. I got this watch through our insurance health program so not sure how I can return it. I was using the sense 1 before this and it always lasted me 5 days. Unfortunately I smashed the screen on it and had to get a new watch. Guess I'll be going back to the sense 1 if I can send this 2 back. So disappointed.:{
07-13-2023 00:23
07-13-2023 00:23
I bought a Sense 2 to replace my Versa (original version) as it had got to the point where it needed to be charged every day. Using the out-of-the box settings for the Sense 2 it needs to be charged as often as the Versa I bought it to replace. Advertising this thing with a 6+ day battery is ludicrous.
