01-12-2025 14:33
01-12-2025 14:33
Does anyone know if you can change one of the 4 icons in the corners. E.G - sleep to step count? I love this clockface and dont really want to.change to a different one but want my steps on the first page rather than having to swipe
Thanks.
Best Answer01-12-2025 20:37
01-12-2025 20:37
Hi @Abbiestephanie - default clock faces are pretty basic with little or no instructions, so unfortunately you probably can't change it's display information.
It may take a little getting used to but you can probably find a far better clock face suited to your needs in the gallery with a lot more customisation and more useful information.
Best Answer01-13-2025 06:34 - edited 01-13-2025 07:41
Hi @Abbiestephanie Facet is the default clock face on the Sense 2. It is a themed clock face, as described in the Gallery, and it cannot be customized.
Laurie | Maryland
