07-05-2024 06:19
07-05-2024 06:19
I recently changed to the Sense 2 and I am using the facet clockface which is the default one. Each corner has a different stat. The heart rate and zones work but the sleep and stress stats don't always display. Usually if I go to 'today' they then appear but this no longer works. I have synced, turn the device off and on again. Is this a known issue and is there a fix? I assume as it's the default clockface it should work! Thanks
07-05-2024 06:33
07-05-2024 06:33
@NessMcD I've experienced this as well. Any clock face with the sleep and stress metrics is hit or miss. The stats sometimes take hours to populate on the clock face despite syncing and restarting the device. I gave up using any clock face that has sleep or stress stats on it.
07-05-2024 08:01
07-05-2024 08:01
Thanks @Heather-S for the reply. That's such a shame as I like the clockface and you would think the one they use on the product box and advertising would be fully functional. I will have a look for another clockface.
