11-14-2023
04:41
08:45
11-14-2023
04:41
08:45
I've had my Sense 2 for a week and the heart rate monitor has NEVER worked. I have spent hours trouble shooting it. Restart, factory reset, change clock face, switch bands, switch wrists, etc. IT. DOES. NOT. WORK. Any further suggestions before I lose it?
@KKurtenbach At this point, you should contact Customer Support for further assistance. It sounds like you've done all suggested troubleshooting methods. Best of luck!
Best Answer@KKurtenbach At this point, you should contact Customer Support for further assistance. It sounds like you've done all suggested troubleshooting methods. Best of luck!
Best AnswerWith the large number of posts relating to the same issue, I’m inclined to think this is a software issue on the newer devices. I used the Sense 2 for nearly 8 months and several other fitbits for over 6 years with no issues until the major software overhaul. I went back to my old Versa 3 and everything is working perfectly. I can’t believe people have been dealing with this for nearly TWO months and Fitbit/Google has not officially acknowledged this problem. Shameful.
Hi @KKurtenbach - when you chat with support as @Heather-S has suggested, be aware if you are unhappy with the watch Fitbit have a 45 day refund policy, this gives you the freedom to try something else.
