12-10-2024
06:23
07:28
DavidFitbit
12-10-2024
06:23
07:28
DavidFitbit
Yes I have done all the basics as per below. My active minues in zone is totally unrealisted and incorrect. A 20 minute job registeres 50 minutes in the zone!! Advice in community it to remove the charge 2 and reconnect. Now because of that great advice I can't sync with bluetooth at all,
Switched iPhobe off and on
Switched bluetooth off and on
Removed Sense 2 - this is my problem now it won't sycn
Done all these thinks repeatedely.
Who has managed to solve this
Hi @Candyfemme.
Thanks for stopping by, i hope you're doing well!
I'm sorry to hear you find trouble with the connectivity between your Sense 2 and your iPhone. Let me help you with that.
Just to make sure, confirm the basics you have performed are those included in our help article Why can't I set up my Fitbit device?below the section "Troubleshooting".
If you still find trouble, let's check the requirements listed in the link above as well.
I hope you will find a solution for your issue. Have a great day.
