11-29-2022 18:56
11-29-2022 18:56
Updated the app and my sense 2 today. Got the on wrist call update and already encountered an issue.... So frustrating. BT won't stay connected for it to accept on wrist calls at all. Turns off right away or fails connection. Anyone else have this issue? I've already restarted everything etc.
11-29-2022 19:44
11-29-2022 19:44
I was trying to answer a few calls today but couldn't connect. I just got the sense 2 a few days ago & haven't read up on it much yet. Are we definitely able to answer calls? I know we can connect to Alexa. I'm missing my Sense, which died too soon but I liked the layout of the tiles & was easier to work with. Please share if you find a solution!
11-29-2022 19:52
11-29-2022 19:52
Have you done the setup as described in this article?
11-29-2022 22:01
11-29-2022 22:01
Yep. You can't not really. You have to enable all the settings for it to setup. It says it's successful but the BT failure is the main issue..... Sigh.
11-30-2022 20:37
11-30-2022 20:37
If you have the latest firmware update, you should have the on wrist call feature but it doesn't stay connected via Bluetooth. I was so excited for this update and to have it not work right off the bat is SUCH a disappointment.... Gawd Fitbit.
11-30-2022 20:42
11-30-2022 20:42
Which Phone do you have?
11-30-2022 20:44
11-30-2022 20:44
Samsung S21U
11-30-2022 20:50 - edited 11-30-2022 20:51
Aha -, well then I have some semi-good news.It is not your Sense, it is Samsung. There is an issue with BT in the latest UI update for Samsung.
11-30-2022 22:55
11-30-2022 22:55
Ahhh! Thank you for this. I just upgraded my phone hours before the Fitbit too. Good to know...
12-17-2022 20:11
12-17-2022 20:11
Mee to, same issue
12-17-2022 20:16
12-17-2022 20:16
I have samsung s22+ and facing same problem
12-27-2022 00:09
12-27-2022 00:09
I have samsung s22U and facing same problem
