08-25-2022 01:31 - edited 08-25-2022 04:05
To use this watch on a phone it states Android 10 or iOS 14 is required.
However preempting an issue, anyone with an older watch without Bluetooth 5.0 who has upgraded to Android 10 or iOS 14 may still not be able to use this watch, even though specs say for syncing
"Syncing requires Bluetooth® LE, an internet connection and location permissions granted on the phone"
Best Answer08-25-2022 04:01
08-25-2022 04:01
@Guy_ Many current Fitbits have Bluetooth 5.0 (Sense. Versa 3, Charge 5, Luxe, I stopped looking). I don't see an issue.
Laurie | Maryland
04:11
08:54
08-25-2022
04:11
08:54
@LZeeW- while it is true the Sense can support Bluetooth 5.0, Fitbit makes a specific point of reporting Bluetooth 5.0 for the Sense 2 while they didn't for the Sense.
Might it actually mean only Bluetooth 5.0 exclusively?
See what is quoted on their site for the 2 watches.
Sense Battery & Power
Battery life up to 6+ days. Battery life and charge cycles vary with use, settings, and other factors; actual results will vary. Use of the always-on display and SpO2 features will require more frequent charging. We recommend charging every few days to ensure you’re always tracking.
Battery type: Lithium-polymer
Charge time: (10-80%): Approximately 40 minutes
Fast charging: 1 day of battery life in 12 minutes
Radio transceiver: Bluetooth®
Sense 2 Battery & Power
Battery life of 6+ days. Battery life and charge cycles vary with use, settings and other factors; actual results will vary. We recommend charging your tracker every few days to ensure you are always tracking.
Charge time (0-100%): Two hours
Radio transceiver: Bluetooth® 5.0
