08-16-2023
13:26
14:25
LizzyFitbit
08-16-2023
13:26
14:25
LizzyFitbit
I received my refurbished replacement Sense 2 and upon trying to set up the device it says this:
” This device has been locked and cannot be paired. This may happen if a device is reported lost or if a warranty replacement has been issued. If you believe this is in error contact support “
I contacted fit bit support and they did not know how to fix it so they suggest I send it back. I’ve already waited three weeks for a replacement… so frustrating!
Does anyone know how to fix this?
08-16-2023 23:03
08-16-2023 23:03
Hi @bestlife78 - a watch can be disabled by Fitbit - in which case they should be able to re-enable it remotely, especially as they sent it to you and it should be working, after it already took so long.
Contact them again and insist they enable it or send you an immediate replacement, as they know it was their mistake in sending you a non functional watch as a replacement.
08-17-2023 04:41
08-17-2023 04:41
08-17-2023 04:50
08-17-2023 04:50
@bestlife78 - this isn't the experience you should be getting and I have escalated it to a moderator. Hopefully a good resolution soon.
08-17-2023 15:23
08-17-2023 15:23
Hi there, @bestlife78. @Guy_ Thanks for the heads up and your great help.
@bestlife78 Thanks for the detailed information and the time taken while contacting our Support team. I understand your point of view and I'm sorry for the inconvenience with your Sense 2. This is definitely not the experience that we want you to have and I appreciate your feedback as it'll help us to work, as well as prevent this type of experience from happening again.
While I don't have access to your case, I've forwarded your posts so our team can review your details and evaluate what can be done to bring you back on track. They'll get in touch with you via email, so please keep an open communication with them.
08-18-2023 03:39
08-18-2023 03:39
08-20-2023 16:02
08-20-2023 16:02
You're welcome, thanks to you for your continued feedback. I'm sure our team will continue working on this matter, so please be sure to follow their instructions and stay in touch with them. I hope we can get you back on track soon.
08-20-2023 17:42
08-20-2023 17:42
08-21-2023 11:43
08-21-2023 11:43
Thanks for keeping me posted. I definitely understand how you're feeling and I apologize for this situation you're going through. Every feedback we receive from our members helps us to improve our services, and yours is truly appreciated.
I've shared your details one more time with our team so they can look into your case and see what can be done to bring you back on track. Please keep a closer eye to your inbox as they'll provide you with more information via email.
08-21-2023 15:27
08-21-2023 15:27
08-22-2023 16:54
08-22-2023 16:54
I totally understand where you're coming from and thanks for taking the time to share your feedback. I went ahead and forwarded all your posts so you can receive an update about this situation as soon as possible. Please keep an open communication with our team as I'm sure they'll be able to provide you with more information about your case.
08-24-2023 14:50
08-24-2023 14:50
08-25-2023 11:51
08-25-2023 11:51
Thanks for keeping me posted. While checking your details, I noticed our team sent you an email with more information about your Sense 2. Because they have access to your case, my best advice is to keep an open communication with them as I'm sure they'll continue helping you via email.
08-30-2023 04:40
08-30-2023 04:40
09-01-2023 14:54
09-01-2023 14:54
Thanks for sharing this update, and I'm sorry your replacement hasn't arrived yet. While I don't have access to your case, I've forwarded your post so our Support team can look into this. My best advice is to reply back to them in order to receive more information about your case, as well as your order.
09-05-2023 09:58
09-05-2023 09:58
09-28-2023 11:42
09-28-2023 11:42
I am going through something very similar. Did you ever get an answer? They are giving me the run around. So my mom gave me her sense 2 and after a week it fell and broke the screen. This was in may. I then requested and looked into if Fitbit had a warranty or replacement. Never heard anything so made it seem like they didn’t. I went out on May 12 and purchased my own Fitbit sense 2 at Best Buy and connected everything just fine. Then I get an email around August about a replacement and it’s delayed. Had no idea what this was. Fast forward to 2 weeks ago I purchased a new iPhone and now trying to pair my purchased Fitbit I’m getting the same error saying it’s locked due to a replacement. I’m so frustrated and confused and Fitbit and google have been giving me the run around. I just want my send 2 unlocked so I can pair it. It’s ridiculous!!
09-28-2023 11:57
09-28-2023 11:57
