02-03-2025
15:27
10:33
LizzyFitbit
02-03-2025
15:27
10:33
LizzyFitbit
I see in 2023 this was a topic answer is again now since I switched it over to Google. No update in the play store. How can I fix it??
Best Answer02-05-2025 09:31 - edited 02-05-2025 09:32
Hi there @Frdracfan! A warm welcome to the Fitbit Community!
Thank you for your question about how to update the app in the Play Store.
Which phone do you use?
Please try to uninstall and reinstall the Fitbit app. Note: Before you uninstall the app, verify that your phone is running a supported version of Android OS. If your phone is on an older version, you won’t be able to reinstall the app. For OS requirements, see Fitbit-compatible devices.
You can try to update the app this way too:
