06-25-2024
06:02
13:32
ManuFitbit
06-25-2024
06:02
13:32
ManuFitbit
My sense 2 stopped working. I charge it and I only see the logo. It constantly vibrates for a fraction of second every 5 seconds.
it doesn’t sync and on the app it shows that it does not exist
Moderator edit: clarified subject.
Best Answer06-25-2024 13:25
06-25-2024 13:25
Hi @Jeksmjek. Welcome to the community forums.
Thank you for sharing the inquiry regarding the situation with your Sense 2. Sorry to know the inconvenience. Thank you for trying to fix it on your own.
I'd suggest following the steps below in the order listed:
If you can't get started with the Fitbit Sense, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Best Answer07-04-2024 11:44
07-04-2024 11:44
It doesn’t get detected by my iPhone
it keeps turning on and off every 2 seconds
Best Answer07-07-2024 04:46
07-07-2024 04:46
Try holding down two buttons at once for ten seconds
mine turned off today while working out and it was fully charged and it wouldn’t turn back on
I’m not sure how
but anyway I saw someone say to hold a button down for ten seconds I tried them all alone and it didn’t work then I held two down for ten second and it turned on
