01-18-2024 05:37
01-18-2024 05:37
I just got my watch a few days ago. I wore it to the first time yesterday to a hiit class. As class started I clicked through on my watch to start the hiit exercise. I noticed there was a 5 minutes countdown displayed when I pushed start. Then it stopped at the bottom of the countdown. I had to restart it over and over then gave up so I could focus on my workout. Not sure what the issue is. I have been flipping through settings to see if there’s something I could change but am not having any luck. Please someone help because if I can’t get this sorted out I am returning it ASAP
Best Answer01-18-2024 22:00
01-18-2024 22:00
The HIIT exercise mode is self guided mode to notify you when to start and stop your interval and for how many iterations. There are settings for that when you swipe up before you actually start the routine. If you are taking a HIIT class where the instructor tells you when to start and stop, you don't need to use the HIIT exercise mode. You probably can select Workout and set a goal, either Minutes (the duration of the class) or Active Zone Minutes (where you get different amount of vibration depending on how hard you are working).
