05-09-2023
08:02
15:42
ManuFitbit
05-09-2023
08:02
15:42
ManuFitbit
Hej
i Have a Fotbit sense wich i use when swimming. The setup for swim is a
pool lenght of 50 meter
the lap rule is set at 50 m
the sta top is pool lenght
middel none
bottom are time
why does the swim not record the correct laps? Latest it was 600 m and the watch recorded 1200…..
why…
hope you can help.
Kirsten
Moderator edit: clarified subject.
05-10-2023 09:02
05-10-2023 09:02
@Kirsten_DK hard to say why it's the case. For me, in a 25m pool, Sense 2 usually adds a few lengths (and sometimes undercounts when I do certain drills). It doesn't double it though. Without proper laps breakdown where you could see which laps are "bogus" and when they happened it's anyone's guess what possibly could go wrong.
05-11-2023
16:26
09:44
05-11-2023
16:26
09:44
Hi @Kirsten_DK. It's good to see you back in the community.
Thanks for the details regarding the inconvenience that you are experiencing with your Sense 2.
Please let me know if you have followed the steps listed here in order to track your swim duration and pool lengths completed with your Fitbit device.
Best Answer05-13-2023 07:51
05-13-2023 07:51
Thanks for your input, observations.
It has only recorded the correct number of laps , distance 1 off all the times i have used it during the last year. Which just anoyes me. And it is always more than a few laps / length. Unfortunately.
Best Answer05-13-2023 07:53
05-13-2023 07:53
As stated in the issue, i have as far as i can see set up the watch according to the guidence. That was the first thing i did, when it did not work.
So hope there are others with input, otherwise i may switch to another brand. Unfortunately.
Best Answer05-13-2023 08:27
05-13-2023 08:27
@Kirsten_DK from all the devices capable of swim tracking Fitbits are the worst (not only due to inaccuracy but because they don't track almost anything about swimming). If swim tracking is important to you, you may be doing yourself a favour by looking at some other brand that understands how to properly track swimming. Fitbit is not one of those brands.
