Opening the Fitbit app on my phone then going to Settings (top right corner), then to Help and Support. Then check for Sense 2 update, the app just sits and spins. It used to show that an update was available or that it was up to date.
Hi @mladd , @Rge - the check for updates is a redundant function anyway, in the sense that if you don't already have a prompt of an update available it will always return up-to-date ( if it is responding).
In other words it will never find an update unless you already had a prompt of one.
