07-31-2024 13:42
07-31-2024 13:42
I routinely walk indoors in a mostly concrete and steel facility and that tends to scew GPS readings. As such I have measured my stride length manually and use my recorded steps to figure actual distance traveled. I used this to edit my first walk with my new Sense 2...utter fail. I'll input the numbers hit save it will show the edit. Then immediately switch back to the original numbers. Little help please.
Best Answer08-02-2024 06:39
08-02-2024 06:39
Hello @TheBigPickleMob and welcome to the Community. Fitbit doesn’t let you edit the distance in tracked exercises. I honestly don’t understand why the distance is on that screen at all.
Laurie | Maryland
08-04-2024 13:12
08-04-2024 13:12
Thanks for the information. I guess I just convert it manually. Apparently yet another Fitbit failure.
