05-01-2023 07:02
05-01-2023 07:02
Every since the latest software update a few weeks ago my sense 2 won’t stay charged..now I seemed to have to charge it all the time..not like before it’s was like every 5 days..anyone else having this issue
05-01-2023 12:20
05-01-2023 12:20
Hi @FWW3 - first try Shutdown from the watch Settings menu. Wait at least 10 seconds before placing on the charger to restart it and charge it.
Second if the problem persists and you see floors missing on the watch but they appear in the Fitbit App change to another clock face.
Third if none of these resolve the problem the watch may be faulty and need replacing under warranty.
You can also chat via the Fitbit App, click profile photo, Help & support, Contact Customer support, they make take you through a factory reset which may not resolve it if the watch is faulty.
Best Answer05-03-2023 01:15
05-03-2023 01:15
Yes...I've noticed that my sense 2 is not staying charged as long. Also, it keeps acting like it is re-setting or something.
05-03-2023 11:34
05-03-2023 11:34
So weird..what I did was go to settings on the watch and scrolled all the was done and hit shut down and left it off for a few seconds before restarting it and put it on the charger and left it there..even for a little longer after it said 100%..seem to fix mine hope it helps you
05-03-2023 21:14
05-03-2023 21:14
I have this too! Yesterday I charged my watch at noon and in the night it went out because no battery left! Less than 24 hours of battery whilst normally it lives almost a week!!! Problem started a few days ago.
05-10-2023
15:26
09:46
05-10-2023
15:26
09:46
I appreciate all this information that you've shared about the inconvenience that you've been having with your Sense 2.
Before considering other options, please make sure that you've followed the steps provided in this article. In addition, try to perform a restart following the steps listed here below, this has been useful for other users experiencing something similar:
The battery can last up to 7 days; because battery life is affected by use and other settings, actual results may vary, but the battery shouldn't be draining only after one or two days. Keep in mind that some of the feature that can drain the battery more rapidly are:
If you're trying to get in touch with the Customer Support team, the best way to get help for this inconvenience is to chat with us online or give us a call. Click here to get connected.
