Sense 2 won't work unless plugged in
ANSWERED
My sense 2 was working fine before the latest update but I don't think the update completed properly. Now my fitbit wont work unless it's plugged in. As soon as it's unplugged it turns off unless turned on again. It is charging and shows the percentage going up. I've tried re-downloading the app and restarting it while it's plugged in. Thinking about factory resetting but afraid that won't work either
1 BEST ANSWER
Accepted Solutions
Welcome to the community forums, @Faultiere.
Thanks for letting me know about your Sense 2, and the steps tried prior to posting. I'm sorry for the experience that you're having and to work on this together, I'd recommend exhausting the troubleshooting steps described in this help article which have worked for other members. Then, monitor the behavior of your watch in the next few days to see how it goes afterward.
3 REPLIES 3
Unfortunately none of these worked. The battery is able to charge fine but won't work off of the charger. I have tried all the suggested tips and even factory reset the device but nothing has worked
Hi there, @Faultiere.
I'm sorry the issue persists with your Sense 2, and thanks for trying the steps suggested above. Given this situation, I went ahead and contacted our Support team; however, I was told that you already have a case created with them. I'm happy your case is in their hands and please reply back to them should you have more questions as I'm sure they'll do their best to help you out!
