12-25-2023 09:48
12-25-2023 09:48
I just got my new S2, and it doesn't appear to be charging. I'm using the cable that it came with, I've tried two different wall plugs and wall outlets, and I'm seeing a lightning bolt, but the level stays at 31%. Has anyone had this issue, and how did you fix it? Thank you!
Best Answer12-26-2023 11:03
12-26-2023 11:03
Hi @ElleMacRow. Welcome to the community.
Thank you for sharing these details regarding the situation with your Sense 2. I'm sorry to know that it's not charging. Thank you for trying to fix it on your own.
Please, confirm that you have followed all the steps listed in this article: Why isn't my Fitbit device's battery charging?
If the device is charging, but the screen is completely black, make sure that you've also completed the restart procedure described here: How do I restart my Fitbit device?
Best Answer12-26-2023 11:08
12-26-2023 11:08
@ElleMacRow check the 4 pins, the one pin is known to get stuck pushed in, and charging will fail
Best Answer12-26-2023 14:54
12-26-2023 14:54
I have the same issue with my S2 that is 13 months old and out of warranty. Charging it became problematic a month ago but responded to cleaning and restarts (10 second reboots) and currently it doesn't charge at all - blank screen. The problem proceeded a software update a few weeks ago.
All 4 pins check out fine on the watch + magnetic coupling and I verified the USB cable is sending current. I followed all the links too.
Any suggestions would be appreciated.
Best Answer12-26-2023 20:53
12-26-2023 20:53
Hi @Nirkeen , @ElleMacRow , as @Rich_Laue says, if one pin is just slightly different to the others, there can be a current but no contact, do check the cable very carefully.
