03-09-2023 20:56
03-09-2023 20:56
I run trails and occasionally my watch will lose the signal, and instead of continuing timing, it turns off. Super frustrating! My Versa didn’t have this issue, anyone have an idea on fixing?
04-05-2023 09:15
04-05-2023 09:15
I have also noticed this. The Versa does keep trying to get a GPS lock and will also use steps to estimate the distance.
The Sense 2 and Versa 4 (they'd units do not use Fitbit OS) seem to quit recording the exercise.
At best the only option I see is to edit the stop time.
04-06-2023 15:27
04-06-2023 15:27
@Rich_Laue And what OS do they use?
04-07-2023 05:44
04-07-2023 05:44
I don't remember what OS but it is not the Fitbit OS that is in the older trackers and why the web based developer won't work for programming. It might also be the cause for the subject of this thread.
For me, knowing what the name of the OS really won't help.
04-07-2023 09:35
04-08-2023 20:06
04-08-2023 20:06
A few months ago I got it from fitbit
04-09-2023 13:38
04-09-2023 13:38
I am experiencing the same thing since the last app update. In order to record my walks I must keep the app open, if I close it it stops counting the distance. Frustrating.
04-09-2023 19:51 - edited 04-09-2023 19:52
@Rich_Laue There is no doubt that Sense 2 / Versa 4 use a new version of Fitbit OS as otherwise Fitbit internal developers couldn't have ported some of the clockfaces in no time (even if they didn't properly them test leaving many bugs behind). Also I'm note sure what do you mean with "...why the web based developer won't work for programming".
04-09-2023 20:56
04-09-2023 20:56
