01-02-2025 11:16
01-02-2025 11:16
Hi I just wondered if anyone can help with syncing to Strava issues from Fitbit sense 2 everything is connected as I’ve used multiple running watches in the past but for what ever reason my watch is not loading the data to my Strava account
10-20-2025 14:56
10-20-2025 14:56
Hi Everyone!
I'm glad to inform you that we've made some updates to the Strava integration that should address issues with workouts syncing between the apps.
Additional Troubleshooting Steps (if needed): Make sure your Fitbit and Strava accounts are connected, please check that you see Fitbit listed under "Manage apps and devices" in Strava settings on the Strava app and ensure that Strava is also listed in the Fitbit app.
Fitbit App: Using a Google Account:
Fitbit App: Using a Fitbit Account:
We always appreciate your feedback, thank you for your patience.
Best Answer01-05-2025 11:56 - edited 01-05-2025 11:57
Hi @Buster1986 .
Regarding the activities you want to sync to Strava, were they tracked using GPS? Unfortunately Fitbit only exports/syncs activities which have GPS data.
You could try using http://www.fittostrava.com/ as a workaround to sync non GPS activities, although I'm not sure if it still works or not (the last time I used it was some years ago).
10-20-2025 14:56
10-20-2025 14:56
Hi Everyone!
