Versa 2 won't turn on unless it's connected to an electrical outlet
My Versa 2 wouldn't turn on so I thought the battery had died. I plugged it into an electrical outlet and it opened up. It still had battery life so that wasn't the issue. I took it off the charger and was able to scroll through it and use it but once it went into sleep mode, and shortly afterwards it again wouldn't turn on. It only turns on for awhile after I plug it into an electrical outlet. I tried resetting it but that didn't help so then I tried a factory reset and that didn't help either. Don't know what to try now.
3 REPLIES 3
It’s nice to see you around the Community Forums @sherD! It would be my pleasure to help you with your Versa 2, which only works when plugged into a power outlet.
Thank you for your efforts to resolve the issue. We want you to get you back on track as quickly as possible.
By entering this help article: Why isn't my Fitbit device's battery charging?, you'll find solutions to the charging issue your device is experiencing. Make sure you follow each step.
I'll be around.
Thank you for wanting to help me but those solutions don't address my issue. I can charge the Fitbit. My problem is that once it's charged and no longer connected to a power source, it won't turn on. It only turns on when it's connected to a power source.
Welcome back to our forums!
Although your device is charging normally, I strongly recommend you try the recommendations listed here. Those may resolve the issue that occurs when unplugging your device from the power source.
If the problem persists, contact support if you haven't already. I am sure they have the right tools to help you further.
Fill out the form. You will then be recommended some help articles. After that, you will be able to choose how to contact support.
