12-29-2022
14:41
12:36
LizzyFitbit
12-29-2022
14:41
12:36
LizzyFitbit
Can the premium trails watch face by Fitbit be adjusted so you can choose what format the temperature data appears in? Or make it pull that from the weather app settings? My weather app is set to degrees Celsius, but on the watch face it appears as Fahrenheit. There currently is no option to change it.
12-30-2022 12:44
12-30-2022 12:44
Hi there, @Ayla15.
Thanks for letting us know about this situation. This is odd as the clock face should use the same units selected for the Weather app. Because this isn't your case, let me recommend the following:
Best Answer12-30-2022 13:56
12-30-2022 13:56
Hi @LizzyFitbit, I tried your suggestions in this order, but it unfortunately didn’t work. Deleting the clock face and re-installing it also didn’t work.
01-02-2023 14:19
01-02-2023 14:19
@Ayla15 It's good to see you here again.
Thanks for trying the suggested steps and I'm sorry you're still having this issue. To look into this, may I know the model and OS version of your phone? Also, if possible, please take a picture of the clock face as well as an screenshot of the Weather app settings. You can attach your pictures to your reply by following the steps from this post.
In the meantime, let's try reconnecting your Sense 2 to the Fitbit app and see if that helps:
Best Answer01-16-2023 13:07
01-16-2023 13:07
I have the same issue here on my new Sense 2, not resolved by doing the suggested.
01-17-2023 08:51
01-17-2023 08:51
Hi
sorry for the long wait, I thought I answered but apparently didn’t. I have a iPhone 13 max pro with iOS 16.2. I’m going to try attaching the pictures in a separate post, because I’m getting errors.
I tried your steps and it unfortunately didn’t work.
Best Answer01-17-2023 08:52
01-17-2023 08:52
Here are the pictures
01-18-2023 09:10
01-18-2023 09:10
A lot of the time the trails premium clock face will not show the information (such as readiness, sleep rating, etc.) It will sometimes it will take hours after waking up to show the information and then later in the day the info will just disappear again
