11-29-2023
10:24
14:03
LizzyFitbit
11-29-2023
10:24
14:03
LizzyFitbit
It's now Nov. 29th and I still have not received a notification to update the Fitbit app. Still showing October 24th as the last update.
I am located in Canada. Is that the reason for the delay.
Hi there, @sparkles4, @nerB and @Kathylynn103.
Thanks for sharing your thoughts about the Fitbit app. As you may know, we released a new Fitbit app version which brings back the battery percentage of your Fitbit device. This update is being released by phases, and while we don't have a specific date when each of our users will get it, rest assured it'll arrive soon. Please note this update is different from the firmware update released specifically for the Sense 2 which should be available to all our users.
Once again, I appreciate your patience and try checking your Play Store or App Store later, and install this update as soon as you see it available.
Best AnswerAlso in Canada.
On November 29, just today, inside the FitBit app, looking at the screen view for my Sense 2, at the top of the screen, I saw a message about updating Tracker Software. I am now up-to-date.
It was not an update in the Play Store. Also, as with other things 'Upgrade' in tech, it is more likely to show if you're charged, plugged in, etc.
14:15
14:11
LizzyFitbit
11-29-2023
14:15
14:11
LizzyFitbit
Thanks for the info. I will look on the screen view for the update tracking software red message every so often.
Update: Finally got my fitbit app. Update. Can now see battery percentage. The update appeared in Google app. Store. Hurray.
Moderator Edit: Merged replies
Hi there, @Kathylynn103 and @1GinnyME1.
You're welcome, thanks to you for the additional information. I'm glad the battery percentage is now displayed on the Fitbit app and because this issue was resolved, I'm going to close this thread from further comments.
If you have any other questions, you can always create a new thread in the forums, or visit the Help Site to find more information about our products and features.
Happy Holidays!
