04-21-2023
13:19
11:43
AndreaFitbit
04-21-2023
13:19
11:43
AndreaFitbit
Hi, My name is Ramin. I have a Sense 2 smartwatch. one of the pins of the magnet charger has been broken and fallen off the charger. Also the wrist band is broken apart and I have to change that too. Where can I change these in Rome, Italy? I don't know if I still have a warranty or not.
Thank you for your help and attention
Best Answer04-26-2023 11:50
04-26-2023 11:50
Welcome to the Fitbit Community, @raminomrani. Thank you for sharing your Sense 2 accessories query.
If you're located in Rome you can contact our Support Team but if you're only visiting this city you can check at one authorized retailler.
Thank you for your advise @Guy_.
04-25-2023 20:25
04-25-2023 20:25
Hi @raminomrani - if it is indeed a Sense 2 it is under warranty as the watch was only available from September 2022.
If you bought it from a shop go there for replacement parts under warranty, if not you can chat via the Fitbit App, click profile photo, Help & support, Contact Customer support.
In addition you can buy straps and charge cables online.
04-26-2023 11:50
04-26-2023 11:50
04-28-2023 07:28
04-28-2023 07:28
Thank you
Best Answer04-28-2023 10:16
04-28-2023 10:16
