Wrong distance daily activity goal on my device display
I am on Fitbit since 2017. I have moved to a Sense 2 ten days ago.
I have noticed that since the beginning my distance daily activity goal is wrong on the Sense 2 device screen -but correct on the Fitbit app.
It sounds like a conversion bug between metric and imperial units. I have indeed set my goal to 10 km and it shows 15 on my Sense 2.
Somebody can confirm whether it is a bug or not? What is the ETA for fixing?
Thanks
3 REPLIES 3
I was just going to ask this same question. My fit bit says goal is 8miles but 5miles I. Teh Fitbit app! Also looking to fix this discrepancy.
@Fredt0  @AudPDX   Yes, it is an imperial/metric bug.  Fitbit is aware it, but there is no time frame for a fix.  You will see it in your app, too.  If you tap on your distance tile, the goal is correct when you are set to Day.  You see it when you tap on Week.  I make my goal almost every day, but the week view shows that I never make it.
Laurie | Maryland
Thank you, clear.
