01-23-2024 07:43
01-23-2024 07:43
Hello, I've been using Fitbit Sense 2 for three months. I'm unsure how to download the ECG reports from the app or dashboard. Can we download ECG reports only in the case of a positive result, or is it possible to obtain them for negative or inconclusive results as well? I don't see an option in my mobile app to download the report of my ECG test. Can someone guide me on how to download ECG reports ? I'm using the feature in Germany and India (Sometimes)
I'm using One Plus 7 and I also don't see the Discover option on the app
Best Answer01-23-2024 08:53
01-23-2024 08:53
Hello @psantoshsan and welcome to the Community. The Discover option refers to an icon that was on the app before it was redesigned. You should be able to find your ECG reports by doing the following:
It takes a few minutes. I use an iPhone and my path to save a report might be different from yours. But it should be self explanatory in the Android app. You can download any recording, normal or otherwise.
Laurie | Maryland
01-23-2024 08:53
Laurie | Maryland
