10-26-2023
10:50
19:59
EstuardoFitbit
10-26-2023
10:50
19:59
EstuardoFitbit
Have had sense 2 for a long time. Never connected to satellite on walks. Now has quit connecting on runs.
Best Answer10-27-2023 05:18
10-27-2023 05:18
Hi @roger71.
The only thing I can suggest is to wear it a little bit looser. Unfortunately the antenna placement on the Sense 2 is very poor, with it being located at the back of the device (the part that sits against your arm). So the tighter you wear it, the worse the signal becomes. Ideally GPS would have a clear line of sight.
