01-10-2022 01:50
01-10-2022 01:50
My Sense is a month old and it needs change on anywhere between 48 to 56 hours (2 to 2 1/2 day). I tried everything, updated software for ios, disabled always on. Always stick to the default close face but no, nothing…. The only reason for buying sense was for it’s claimed battery life… which I felt is wrong… completely wrong.. not sure if it’s working for android but for ios not lasting even the half of claim….. dissatisfied and highly disappointed.
01-10-2022 04:01
01-10-2022 04:01
Hi @Abhi.k.pandey That doesn't sound right. Are you using GPS at all? That will use up your battery.
Have a look at THIS Help Article on battery life to see if there is anything there that helps you. If not, then I'd suggest you contact Customer Support as it doesn't sound right to me. I use an Android with my Sense and get something like 6 days or even more from my battery
Helen | Western Australia
01-10-2022 05:36
01-10-2022 05:36
HI @Abhi.k.pandey - carefully review all the options listed to eliminate any you don't need How to resolve the Major issues causing short battery life.
01-11-2022 01:28
01-11-2022 01:28
Hi, I can’t comment on Android
01-11-2022 02:01 - edited 01-11-2022 08:29
Check to see if snore report and or readiness reports are enabled. Snore report is a notorious battery drain over night. Also may wish to consider closely monitoring battery drain for a day or two and see when the battery usage is the greatest.
