Hi brenp23... when you say you 'restarted it', did you hold the button for 10+ seconds until the Fitbit logo came up? If not, then maybe try that first. If you can successfully get the Sense re-set, then try pairing with your iphone again. (i.e. delete the BT device on the iphone and then set things up again).
Hope this helps...
Best AnswerYes, I held the button down for 10 seconds and it started loading but got stuck on the logo screen. It had never finished installing when I restarted it, which I did because it was installing for hours, and now I think it's unable to load. The iphone fitbit app doesn't recognize it. I'll try to uninstall it and see if that helps.
