02-14-2022 05:37
02-14-2022 05:37
And I've worn it 24/7 except for short intervals charging. I don't expect a sleep score, I"ve had fitbits for years and rarely get a sleep score, but the rest? All I get for health metrics is resting heart rate. It's been measuring my skin temperature but not last night.
Ok, the technical answer seems to be for some of this not sleeping for at least 3 hours. But Saturday it tells me I was asleep, without even being restless, for 263 minutes, over 4 hours.
Best Answer02-16-2022 11:28
02-16-2022 11:28
Hi, @DougWeller, may I suggest a couple of additional steps. Firstly make sure the back of your "Sense" is clean, you report regular charging and do not mention problems, that indicates the contacts are clean, make sure the LED/sensor array is also clean. I use warm soapy water and a cotton bud to get gently into the little depressions. Try restarting your "Sense"> from the clock screen>swipe left to settings>swipe up to shut down>confirm. Restart by holding down the side button until the logo appears (your data is safe)
You may find this article How do I track my sleep with my Fitbit device? offers a way forward.
If you are still stuck please post here again.
Cheers
Gr4ndp4 | UK
Best Answer02-17-2022 03:39
02-17-2022 03:39
I've just noticed my sleep tracking is set to sensitive, that might be the problem. We'll see. Thanks for your help.
Doug
