Frequently my sleep is incorrectly logged, starting later than it really was or continued after I wake up. In the previous UI I could edit the times, but no longer. When I try now, I get an error message "Can't save sleep session...already logged". So, what is the edit function for?
Best Answer@42bitwise Can you please clarify that you are using the Edit sleep function and not the Log Sleep function? You tap on your Sleep tile > tap in the three dots in the upper right > Edit Sleep > Edit and make changes. Your error message sounds like it coming from a Log Sleep path. If you are following the correct path, do you use an Android or iPhone and what app version do you have? There might be a bug in the app. I use an iPhone and am not having this issue.
Laurie | Maryland
Laurie | Maryland
Best Answer@42bitwise No harm, no foul. 😉
Laurie | Maryland
