01-14-2021
12:19
06:14
WilsonFitbit
01-14-2021
12:19
06:14
WilsonFitbit
I thinking of getting either versa 3 or sense.... but I'm so torn. Any suggestion or reasons to get one vs the other would be greatly appreciated. Thanks.
Best Answer01-14-2021 12:31
01-14-2021 12:31
The biggest difference is the Sense has ECG for AFib detection, and a few other smaller features, but ECG is the biggie.
In most other ways, they are identical. My view is Sense is worth it if concerned about AFib, otherwise Versa 3 might make sense (bad word choice).
Best Answer01-15-2021 01:37
01-15-2021 01:37
Hi @KLaei I agree with what @JohnnyRow says. Id go Sense because I like that it does more, even though I dont use some of the features at the moment. I have found their performance pretty comperable, but I like the bells and whistles of the Sense.
Helen | Western Australia
Best Answer01-15-2021 03:40
01-15-2021 03:40
My input
Sense should be considered a Versa 3 Pro as essentially it is the same watch with few more features. Namely
- ECG sensor
- dedicated skin temperature sensor (Versa 3 uses a more classical one, not sure actually about the difference)
- EDA sensor (stress sensor)
- Gyroscope (essential if you are a swimmer as the Versa 3 will not show you laps in real time)
I'm actually more inclined towards the Versa 3.
Best Answer01-15-2021 06:13
01-15-2021 06:13
Hello @KLaei Welcome to the Community Forums! @JohnnyRow @NellyG @Giampi71 Thanks for the input and information you shared!
Besides the information shared, you can also visit the manual of the Sense and Versa 3 to get more details about the functionalities of each Fitbit device.
See you around.
Best Answer01-15-2021 11:45
01-15-2021 11:45
Thank you, I got the sense 😊
Best Answer01-16-2021 06:47
01-16-2021 06:47
@KLaei I am glad to know that you got the Fitbit Sense!
See you around!
