02-26-2021
08:00
10:47
WilsonFitbit
02-26-2021
08:00
10:47
WilsonFitbit
Thinking of buy the Fitbit sense what are people thought on this
Best Answer02-26-2021 09:36
02-26-2021 09:36
There are some issues with the heart rate accuracy, if thats important to you probably wait till it gets an update or a newer version. Vibrate is also weak but it looks nice and works reasonably well otherwise. Some things don't work depending where you live.
02-26-2021 09:52
02-26-2021 09:52
Best Answer02-26-2021 15:23
02-26-2021 15:23
For health tracking I wouldn’t recommend sense to you.
It has a serious issue related to the heart rate accuracy. Mainly while exercising you will notice clearly this issue.
Blood oxygen saturation measured only while sleeping.
02-27-2021
04:16
13:06
02-27-2021
04:16
13:06
Hello @Shedend, @Rami.Khalawi, welcome to the community forums! @Guy_, it's great to see you around and thanks for your input! @Rami.Khalawi, I also appreciate your input and feedback!
@Shedend, I also recommend checking the following link to get more information about our different Fitbit devices. Here, you will be able to take a quiz to see which device will better suits your needs.
See you around.
