08-04-2021
14:24
09:55
AndreaFitbit
08-04-2021
14:24
09:55
AndreaFitbit
I have noticed several requests for this over the past few years, but wanted to check on this, since I recently got my Sense. Is there any way to customize the hourly goal of 250 steps or change the alert from 10 minutes before the end of the hour? I would like to either increase the number of steps, or set the reminder earlier in the hour to better fit my work environment. If there is currently no way to do this, please consider adding it in the future. Thank you.
08-05-2021 03:30
08-05-2021 03:30
Hello @darthmaulian and welcome to the Help forum. I'm sorry, but you can't customize the number of steps or the reminder time. I didn't search the Feature Suggestion forum for details, but my experience tells me that Fitbit has no plans to change this.
Laurie | Maryland
Best Answer08-05-2021 08:49
08-05-2021 08:49
Welcome to the Fitbit Community, @darthmaulian. Thanks for sharing your hourly step goal inquiry.
As @LZeeW, mentioned this feature can't be customized. I looked for a Feature Suggestion and found: Increase or Customize Reminder to Move from 250 Steps/Hr.
Keep on visiting the forums.
08-05-2021 09:49
08-05-2021 09:49
You could try a clock face from the gallery, such as SimpleClockPro which has reminders at 40, 50 and 55 minutes and can do more than 14, amongst other things.
Best Answer08-05-2021 10:07
08-05-2021 10:07
