App Update 3.52 (1083) & 3.52.1 (1084)
Fitbit App 3.52 (1083) and 3.52.1 (1084h in iPhone App Store last few days.
Update your app and see if it fixes any issues you may be experiencing.
Sense Activation 11/3/20\IPhone 12 Pro Max\SimpleClockPro Watch Face\Spigen Rugged Armor Pro Case/Band
3 REPLIES 3
@Clove6060- Do you still see these versions?
3.52 has disappeared from my Android Play Store.but may be exists for others [latest shown is 3.51.1]
@Guy_
I updated the 3.52 in the Apple App Store  then a few days later 3.52.1 showed up and I updated that.
I’m able to see the version history when it became available.
Right now I only see in appl App Store the fact I downloaded the 3.52.1 recently and have the ability to open it. It’ll drop off visually after a bit as well.
This is the app version showing in my app right now.
I do not see in the App Store where 3.52 was updated. It dropped  off my list of updated recently.
I scrolled down further and it is gone from my list.
Maybe someone who has not updated 3.5.2 can see both in the App Store available to update. Idk
Thanks @Clove6060  - probably only one version will be visible in the Play Store at a time, and not necessarily the same for everyone at the same time.
If a version [of the same release] has to be deployed for different types of phone it make take a while to get all the versions available for everyone.
