01-14-2021
18:24
03:58
WilsonFitbit
01-14-2021
18:24
03:58
WilsonFitbit
Are we able to get phone calls and texts now? I was told that the software update would be late 2020. Thanks
Best Answer01-16-2021 16:29
01-16-2021 16:29
@deamo5333 yes, you should be able:
Good luck!
01-14-2021 21:33
01-14-2021 21:33
Hi, it works fine, here's how
In the phone Fitbit App Click on profile photo [top left] Device photo [middle left] Notifications And verify the top 4 items are correctly defined. Also App notifications and select any other apps you want to hear from. |
If you use Google Assistant, that works great too on the watch.
03:57
09:09
01-15-2021
03:57
09:09
Hello @deamo5333 Welcome to the Community Forums! @Guy_ Thanks for the input!
To take advantage of the features of your Sense like call and text notifications, you must install the Fitbit App on a compatible mobile device. For a list of compatible devices, please go here: Which phones and tablets can I use with my Fitbit watch or tracker?
To setup notifications, I recommend taking a look at this help article: How do I get notifications from my phone on my Fitbit device?
Keep me posted.
Best Answer01-15-2021 04:30
01-15-2021 04:30
Best Answer01-15-2021 04:31
01-15-2021 04:31
Best Answer01-15-2021 12:57 - edited 01-15-2021 12:58
@deamo5333 this should still work. Enable Sense controls. Your tracker becomes a Bluetooth headphone.
Best Answer01-15-2021 13:06
01-15-2021 13:06
06:52
09:09
01-16-2021
06:52
09:09
Hello everyone. @Rich_Laue Thanks for the input!
@deamo5333 It's a pleasure.
See you around!
01-16-2021 16:29
01-16-2021 16:29
Good luck!
01-16-2021 16:37
01-16-2021 16:37
01-16-2021 16:43
01-16-2021 16:43
@deamo5333 Awesome! Just let us know how it goes. 😁
