04-24-2021 19:29
04-24-2021 19:29
I just upgraded to a sense from a blaze. Previously I always received notification of a BBM message on my blaze but that doesn’t appear to be working and as far as I can tell I’ve checked all my settings and they seem ok ?
Best Answer04-24-2021 19:57
04-24-2021 19:57
Did you check App notifications underneath notifications?
Best Answer04-24-2021 20:02
04-24-2021 20:02
I can’t seem to open the notifications field everything else on that page I can but that
Best Answer04-24-2021 20:09
04-24-2021 20:09
Its a problem with the Fitbit App, clear the cache and force stop it in Android
Possibly logging out and in may resolve it or uninstalling and reinstalling on iOS.
04-24-2021 20:25
04-24-2021 20:25
You’re amazing thank you !! Had to uninstall and reinstall the app was able to get into it and got it fixed thank you !!
Best Answer04-25-2021 11:14
04-25-2021 11:14
BBM Enterprise notifications work on my Sense. I see you've solved the issue, great!
