04-28-2022 12:54
04-28-2022 12:54
Hello, I just got me sense a few days ago. I fully charged it once and today it’s suddenly dropped to 15% charge. It says it should last 6 days. It’s only made it a day and a half. I don’t see an always on setting and not sure what else could be doing it. Before I charged it fully it arrived partially charged and went for a few days on that partial charge. This time it hasn’t.
04-28-2022 13:04
04-28-2022 13:04
Hi, @Zyante please swipe left on your Sense until you come to the settings menu. There you will find display options which could affect battery life: brightness, always on, and screen timeout.
On the settings menu you will also see the option to shut down. It is a good idea also to shut it down and then restart (hold the button) as this can shut down any background activities that could be affecting your battery life. You will not lose any data doing this.
04-28-2022 13:15
04-28-2022 13:15
04-28-2022 13:40
04-28-2022 13:40
Please do check your settings as mentioned above.
If the display is set to normal, “always on” is turned off and display timeout is set to 10 secs, and especially if a brand new Sense battery is draining while it is actually plugged in to charge (!) , and you have confirmed that it is connected to a charging plug known to be working, then it is probably time to get in touch with Fitbit Customer Support on Contact.Fitbit.com
Keep us posted!
04-28-2022 13:58
04-28-2022 13:58
04-28-2022
14:13
09:50
04-28-2022
14:13
09:50
Your phone’s battery should not affect it. Have you checked whether the display timeout is set to 10 secs - a longer time will affect battery life, as will setting the display brightness to max (although the bright setting should have only minimal impact).
If it is charging properly now, I would suggest monitoring it for a few days and seeing how it goes.
04-29-2022 08:13
04-29-2022 08:13
04-29-2022
19:59
09:51
04-29-2022
19:59
09:51
Hi @Zyante - here's a longer list of things to check for the battery life, often caused by using all features released in the latest firmware and app versions.
How to resolve the Major issues causing short battery life
