02-14-2022 09:00
02-14-2022 09:00
My Sense is draining and needs to be charged almost every day. It was fully charged yesterday, went for a hike and came home and it was at 28%. I saw there is an issue with the IOS platform. Is a similar issue happening with the Android as well?
Best Answer02-14-2022 10:30
02-14-2022 10:30
Hi @Mustangrainie66 - there are a lot of new features which might all be enabled - try removing them all to see if you can get normal battery life and then add the ones your need. Here's the list of the main drainers How to resolve the Major issues causing short battery life.
