11-01-2021 18:49
11-01-2021 18:49
My Fitbit Sense, purchased November 2020. Ser # 2C132ED6E929 Nov 1, 2021
In the past month (Oct) my Fitbit Sense seems to have changed in Battery life a lot shorter..
My routine is charging it every day from 6:30 PM to 7:30 PM (Virtual no exception) and charger has 4 point contact.
It always showed when starting charging 82% to 84% and after charging it is back to 100%.
In Early October it seems to start use more energy even on occasion it warned during the day a very low remaining charge of 12% (this was within 12 to 15 Hours after charging (did I make a error?)
I then did make double sure that after the charging cycle the battery charge show 100%.
Sometimes it was normal (82% to 84%) but other times it’s considerably lower 50% or less after the 100% charge.
The Fitbit Sense is always up to date with the newest Soft/ Firmware, I tested the Sense by removing all devices that communicated (Desktop and Smartphone), Set Display time at lowest setting and Brightness at standard setting I also removed the automated display view with wrist movement.
TESTING FOR SEVERAL DAYS (with no external load on the Fitbit (No other devices, No wrist move display etc.)
Thursday, Oct 28 – 7:30 PM – Battery 100%, Fitbit Sense fully loaded.
Friday, Oct 29 – 6:30 PM – Battery 61% in 22,5 Hours (with no load. (No desktop/ smartphone/ wrist movement)
Friday, Oct 29 – 7:30 PM – Battery 100%, Fitbit Sense fully loaded.
Saturday, Oct 30 – 3:30 PM – Battery at 58%, Reading about issues with Fitbit and decide to do Factory reset
Saturday, Oct 30 – 3:39 PM – Factory Reset ok, latest firmware version 44.128.5.49 update took very long till 11.00 PM
Sunday, Oct 31 – 6:30 PM – Battery 89% Sense seems to be ok again of course no extra load (and 3 ½ hrs. less)
Sunday, Oct 31 – 7:30 PM – Battery 100%, Fitbit Sense fully loaded.
Monday, Nov 01 – 6:30 PM – Battery 86 % all systems go, Factory Reset and Firmware 5.9 does the Job……..
Best Answer11-01-2021 19:54
11-01-2021 19:54
11-01-2021 20:05
11-01-2021 20:05
Hi @MurrayHartman this article - click to read - explains how to extend battery life. Hope your battery holds steady for you.
11-01-2021
23:29
06:09
11-01-2021
23:29
06:09
Hi @MurrayHartman - are you saying that a firmware update was the probable cause for the short battery life?
And that a factory reset afterwards cured it?
What firmware version are you on now? The one it came with or 44.128.6.12?
Best Answer11-02-2021 06:47
11-02-2021 06:47
Best Answer11-02-2021 06:52
11-02-2021 06:52
What firmware version are you on?
Best Answer11-02-2021 06:58
11-02-2021 06:58
Best Answer11-02-2021 08:54
11-02-2021 08:54
Curious outcome. If its working I would stay on that version of firmware because there is a newer one and its odd you didn't get that one.
Best Answer11-02-2021 09:09
11-02-2021 09:09
09:28
06:09
11-02-2021
09:28
06:09
Thanks for the feedback, it makes sense, The newer release was only starting to be rolled out on the 27th October and presumably not yet reaching you yet. It can take quite some time for it to rolled out to everyone.
What is still odd, is that a factory reset resolved the bug in the 44.128.5.49 which was causing rapid battery drain, like it didn't get properly installed when it updated.
Best Answer11-02-2021 09:52
11-02-2021 09:52
Best Answer11-02-2021 10:21
11-02-2021 10:21
Hey Guys how do you get the new firmware and do a factory reset?
11-02-2021 10:39
11-02-2021 10:39
Fitbit posted about it just an hour ago - click to go to that announcement
11-02-2021 10:42
11-02-2021 10:42
11-02-2021 10:49
11-02-2021 10:49
@reginaruss - factory reset comes with much to do, so it's only recommended as a last resort because things can turn out not as expected.
11-02-2021 10:51
11-02-2021 10:51
thank you Guy_ good information.
Best Answer11-02-2021 10:55
11-02-2021 10:55
Best Answer11-02-2021 11:02
11-02-2021 11:02
