07-21-2021 11:18
07-21-2021 11:18
I have a black tattoo right at the spot where the Fitbit should be so it will not detect my HeartRate there. I am now now sure, is it better to wear it on my non dominant hand but under the wrist instead of on top OR on my dominant hand on top of the wrist?
Best Answer07-21-2021 11:34
07-21-2021 11:34
Hello @Sigrunpuki it seems those of you with tattoos have a more difficult time with the sensors. I found two posts that might help you. This member found switching wrists did the trick and this member moved it slightly closer to the hand to get it to work. If you do a search, you'll see a few posts about tattoos. One member a while back put white surgical type tape on the area to cover a tattoo when wearing the Fitbit. Hope you find a way to get it to work for you.
Best Answer07-21-2021 12:17
07-21-2021 12:17
Thanks, I was mainly wondering witch obtain would give me a better, more accurate reading?
Best Answer07-21-2021 12:18
07-21-2021 12:18
Sorry, which option, not obtain
Best Answer07-21-2021 12:35
07-21-2021 12:35
Check the first of those posts, the member switched wrists and you can compare notes.
