04-06-2021 09:37
04-06-2021 09:37
today i received my fitbit sense. Unfortunately the charger does not work. I have tried the charger on multiple usb chargers but none works (PC, iphone charger, ipad charger, “family charger”). If I put the USB cable from the Fitbit Sense into my family charger (4x USB outputs), the other USB outputs also fail (with or without a connected Fitbit). It seems the fitbit charging cable causes the family charger to malfunction. I suspect the problem is with the included fitbit charging cable. The Fitbit Sense seems to be working ok.
Best Answer04-06-2021 10:03
04-06-2021 10:03
I am so sorry you are have difficulties charging your Sense. This is what I could find for a new device (this was found in the following link Why isn't my Fitbit device's battery charging?😞
| Your device's battery won't charge after you remove it from the box. | Confirm that you removed the plastic protective cover from the back of the device. |
Assuming the plastic covering was not the issue, I would suggest contacting support. The support contact information can be located at the bottom of the link provided above,
Best Answer04-06-2021 10:23
04-06-2021 10:23
Hi Cathm,
Thank you for your answer. The plastic cover wasn’t the issue. I already tried to contact fitbit support. The Live Chat isn’t working and fitbit is no longer offering support by e-mail. Fitbit Customer Support suggest the following:
The help site can’t solve my problem and I neither want to replace my wristband. The third and last option was to visit the community forum.
It isn’t easy to contact Fitbit......
Replacing the charging cable would, in my opinion, likely solve the problem. And if it doesn’t I can still replace my Fitbit Sense.
Best Answer04-07-2021 03:37
04-07-2021 03:37
I managed to contact the Fitbit Costumer Live Chat. They will send a new charging cable. Hopefully that will fix the problem.
Best Answer04-13-2021 14:21
04-13-2021 14:21
The new cable fixed the problem. Happy with my fitbit Sense now!
Best Answer04-13-2021 15:18
04-13-2021 15:18
That is great news @Roel_kokonut!!!
